Need help with this Code, Please
Kingdom Man
Hello, I am programming a 16f690 and I want to trigger one of my outputs to go high based on one of my inputs going high momentarily. I basically want to have a push button, when the button is pressed- it triggers one of my outputs to go high and stay high.
You didn't say what language.......so not being a mind reader, I get to choose?
#chip 16f690,8
#config INTRC_OSC_NOCLKOUT
dir PortA.0 in
Main:
If PortA.0 On Then
    wait 30 ms
    If PortA.0 Off then goto Main
    Set PortA.1 On
End if
Do
    nop
Loop
goto Main
You know I bet not one person on the forum will tell you how to do that.
and it work good in assembly
It's like this press switch led on press same switch led off
How do you do that
You test for button press and test for led to be off
If button pressed and led off turn on led
If button pressed and led on turn off led
This will do what you want maybe some one can post something better
#include <p16F690.inc>
     __config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF)
     	cblock	0x20
	d1
	d2
	endc
	org 0
init:
	banksel ANSEL		;switch banks
	clrf	ANSEL 		;digital I/O
	banksel TRISA		;bank switch
	movlw	b'00001000' ;set ra3 as input
	movwf	TRISA
	banksel PORTA		;switch to banks
	clrf	PORTA		;set all low
	banksel TRISC		;swich banks
	movlw	b'00000000'
	movwf	TRISC		; set port to all outputs
	banksel PORTC		;switch banks
	clrf 	PORTC
	goto 	start    	;goto main program
start:
	bcf 	STATUS,RP0
	btfss	PORTA,3
	call	test
	call    Delay
	goto 	start
test:
	call    Delay
	btfss	PORTC,0
	goto	on
	goto	off
	return
on:
	bsf		PORTC,0
	return
off:
	bcf		PORTC,0
	return
Delay
			;4993 cycles
	movlw	0xE6
	movwf	d1
	movlw	0x04
	movwf	d2
Delay_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	Delay_0
			;3 cycles
	goto	$+1
	nop
			;4 cycles (including call)
	return
 end
I call that turning a analog button into a digital switch
EDIT:
Hey Burt u know im not picky at all but that one line it bothers me heh :)
also that code wont work right he wants it to stay on so he either needs to check a flag or just opposite the pin.
Here ya go:
     org 0
	cblock
	d1
	d2
	flag
	endc
init:
	movwf	TRISA
	movlw	b'00000000'
	movwf	TRISC		;set port to all outputs
	movwf	flag		;init out flag with 0 aka off
	clrf 	PORTC
start:
	bcf 	STATUS,RP0
	btfsc	PORTA,3		;check if button is pressed (PULLED LOW - PRESS = HIGH)
	call	toggle		;if pressed (HIGH) call toggle
	call    Delay		;if not press or when returning from toggle call delay
	goto 	start		;repeat it all
toggle:
	btfsc   flag,0		;check if flag is cleared if so turn it on
	goto	off			;if not and flag is set turn it off
on:
	bsf		PORTC,0		;turn led on
	bsf		flag,0		;set our flag
	return				;go back
off:
	bcf		PORTC,0		;turn led off
	bcf		flag,0		;clear flag
	return				;go back
Delay
	movlw	0xE6
	movwf	d1
	movlw	0x04
	movwf	d2
Delay_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	Delay_0
	goto	$+1
	nop
	return
 end
Atom the code works it's using the led as a flag lol. Only bad thing about that is you can see the Led flicker as the switch bounce.
Atom your code doesn't work at all I think its because your checking for the switch to go high That's not it . Don't take my word you got one of these try it for your self **broken link removed**
SW1 on that is for RA3 but the JP5 must be connected and JP1 for led
https://www.electro-tech-online.com/custompdfs/2009/08/Low20Pin20Count20User20Guide2051556a.pdf
Connect JP1 and JP5 and this should work:
     org 0
	cblock
	d1
	d2
	flag
	endc
init:
	movwf	TRISA
	movlw	b'00000000'
	clrf 	PORTC
start:
	bcf 	STATUS,RP0
	btfss	PORTA,3		;check if button is pressed
	call	toggle		;if pressed call toggle
toggle:
on:
	return				;go back
off:
	return				;go back
Delay
	movlw	0xE6
	movwf	d1
	movlw	0x04
	movwf	d2
Delay_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	Delay_0
	goto	$+1
	nop
	return
 end
https://www.electro-tech-online.com/custompdfs/2009/08/Low20Pin20Count20User20Guide2051556a-1.pdf
     org 0
	cblock
	d1
	d2
	flag
	endc
init:
	movwf	TRISA
	movlw	b'00000000'
	clrf 	PORTC
start:
	bcf 	STATUS,RP0
toggle:
on:
	return				;go back
off:
	return				;go back
Delay
	movlw	0xE6
	movwf	d1
	movlw	0x04
	movwf	d2
Delay_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	Delay_0
	goto	$+1
	nop
	return
 end
Thats only if you cut them I haven't cut my jumpers
Atom the board is made with the jumpers set to use leds and switch you cut the tracks and add two pin headers for jumpers only if you cut the tracks
Atom the switch is high going low on press there are four leds on portC 0-3
that's how the board works OK
Your code turns on all the leds that's funny because I can't see that happening
Atom whats 'the part in red for your not calling it
     org 0
	cblock
	d1
	d2
	flag
	endc
init:
	movwf	TRISA
	movlw	b'00000000'
	clrf 	PORTC
start:
	bcf 	STATUS,RP0
toggle:
[COLOR="Red"]on:
	return				;go back[/COLOR]
off:
	return				;go back
Delay
	movlw	0xE6
	movwf	d1
	movlw	0x04
	movwf	d2
Delay_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	Delay_0
	goto	$+1
	nop
	return
 end
heh yes i am...
If the flag is cleared it goes to the red you highlighted if its set then it goes to off
hence why this should work fine:
	cblock 0x20
	d1
	d2
	flag
	endc
     org 0
init:
	movwf	TRISA
	movlw	b'00000000'
	clrf 	PORTC
start:
	bcf 	STATUS,RP0
toggle:
on:
	return				;go back
off:
	return				;go back
Delay
	movlw	0xE6
	movwf	d1
	movlw	0x04
	movwf	d2
Delay_0
	decfsz	d1, f
	goto	$+2
	decfsz	d2, f
	goto	Delay_0
	goto	$+1
	nop
	return
 end
Atom the Op has the same board let him see how it works
your code just turns the leds on on PORTC
My code turned RC0 on and it stayed on till you press the switch but you can see the bounce of the switch because I was using RC0 as the flag
Here why all the leds where coming on
	cblock	0x20
	d1
	d2
	flag
	endc
	org 0
Look at the code you posted Atom
	cblock	0x20
	d1
	d2
	flag
	endc
	org 0
heh i copied the main code from you since i never used that PIC before i assumed you had it correct :D
Atom I didn't put a debounce delay in at first then I cut and pasted I messed the 0x20 part
and put it after the org 0 LOl
Your code works now mine worked like it was and and now the debounce delay is working
they both work the same
