Need help with the "Sound Activated LED Flasher Circuit"
damende53
from circuitdesign.org.
I have made two changes from the original design. I am only using one LED not two and I'm using RadioShacks MPS2222A NPN transistors instead of the 9013's.
I have tested all of the parts out of the circuit and they do verify within spec's (the only exception to that is the surface mount mic that I have). I cannot figure out who the manufacturer of the part is (bought it to fill out a minimum order sort of thing). However is does show continuity across the leads.
If anyone is familiar with this circuit and knows of any changes that need to be made please send me an e-mail at:
Thank you for any help you can offer.
Why didn't you post the schematic?
The website you posted does not have the circuit.
Google shows a circuit with the same name on another website. It this it?
It is designed completely WRONG!
Yes, that is the design that I am working with.
Thank you for your insight. I'll make some adjustment today to see if I can get it to work.
I fixed the awful circuit and it simulates well when the transistors are "typical". It is faily sensitive and the LEDs blink with normal conversation and music. The max current in the LEDs is only 10mA each which should be fairly bright. Use only red LEDs.
