Arya Dhani
First of all let me tell you that I have next to zero knowledge about electronics. I am a newly retired accounting/finance man and I am trying to make something electronic so I really need your help with these question to begin with:
- I just purchased a home-made strobo light device that uses a xenon bulb that will flash repeatedly after you push the "on" button.
- The device uses a couple of high capacity capacitors.
- I want to replace the xenon bulb with a coil inductor (am I using the correct term?) that will produce powerful magnetic pulse (almost like the one in a coil gun, but I am not making a coil gun)
- The magnetic pulse will be time variant. It will pulse only when you push a switch - I am thinking of a "reset switch button?"
- I was told that if I just replace the xenon bulb with an inductor coil it will get overheated because the current needs to be dissipated (such as going to the xenon bulb).
- Can I install an indicator light that will indicate when the capacitors are full and so ready to discharge? Something like a "ready" button on a camera flash.
