Need Help With 16F676 Counter
I'm working on a project that will eventually be a 3 digit counter but I have a small issue I believe is in the code I wrote. The circuit is a PIC16F676 driving 3 common anode multiplexed 7 segment displays with the anodes driven by MOSFETs. Just to test things out I wrote some code just to alternate a "1" between the ONES place and TENS place. So far that works ok but the HUNDREDS digit wants to turn on randomly. It seems the gate of the MOSFET controlling that digit is "floating" even though it is connected to pin 4 (RA3/MCLR/Vpp) of the PIC. I have put a logic probe directly on pin 4 and verified a state that's neither H nor L. Have I done something wrong in the code or is it that I just can't wire the circuit like I have it?
Sorry for the messy post, the "insert code" box doesn't work for some reason.
        #include <p16f676.inc>
       List   P=16F676
       __CONFIG   _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
COUNT1  equ 20h           ;First counter for our delay loops
COUNT2    equ 21h           ;Second counter for our delay loops
COUNT3   equ 22h           ;Third counter for delay loop.
                       ;20h, 21h, 22h, are addresses in the general register
                       ;that are used to store a variable
Start
       BSF       STATUS, RP0                   ; Bank 1
       CLRF   TRISA                       ; PortA all output
       CLRF   TRISC                       ; PortC all output
       BCF       STATUS, RP0                   ; Bank 0
       movlw   b'00111111'       ;
       movwf   PORTC           ;set all of PORTC high turning segments off
       movlw   b'00101101'
       movwf   PORTA           ;set RA5 high to turn segment g off and
                               ;set RA0,2, and 3 H to turn digit off
Main
       movlw   b'00010111'       ;set RA3 and RA5 low to turn on segments b and c
       movwf   PORTC
       movlw   b'00101001'       ;select digit 1 (LSD)
       movwf   PORTA
       call   Delay
       movlw   b'00101100'       ;select digit 1 (LSD)
       movwf   PORTA
       call   Delay
       goto   Main
Delay
       movlw   D'200'           ;load decimal 200 into w
       movwf   COUNT1           ;move 200 to f then to variable COUNT1
       movlw   D'200'           ;COUNT1=200, COUNT2=200, COUNT3=4 gives a nice flash rate
       movwf   COUNT2
       movlw   D'4'
       movwf   COUNT3
Loop1      decfsz   COUNT1,1     ;decrement variable COUNT1 by one
           goto     Loop1        ;goto Loop1 if COUNT1 is not zero, skip this step if it is zero
           decfsz   COUNT2,1     ;next decremented counter...
           goto     Loop1
         decfsz   COUNT3,1     ;next decremented counter...
           goto     Loop1
         return
       end
Code tags help alot
List P=16F676
Start
movlw b'00111111' ;
movlw b'00101101'
Main
movwf PORTC
movwf PORTA
call Delay
movwf PORTA
call Delay
goto Main
Delay
movwf COUNT2
movlw D'4'
movwf COUNT3
goto Loop1
goto Loop1
return
end
Code tags help alot
List P=16F676
Start
movlw b'00111111' ;
movlw b'00101101'
Main
movwf PORTC
movwf PORTA
call Delay
movwf PORTA
call Delay
goto Main
Delay
movwf COUNT2
movlw D'4'
movwf COUNT3
goto Loop1
goto Loop1
return
end
Thanks, I couldn't remember how to do it.
If you use [code=MPASM] code [/code] it works even better in "technicolor."
Not sure of the problem. Will have to look at it in the morning.
John
Unfortunately RA3 is input only. Some of the newer chips are pic compatible and RA3 is I/O.
Edit, Actually, I'm not sure if even the newer chips have RA3 as output.
Yes, all are I/O but RA3 is Input only. See page 21 of datasheet.
Sorry,
