I really hope someone can help me with this project. I am new to this forum but appreciate any feedback.
I am working on a fire department ladder/aerial truck. The problem: There are strobe lights that are mounted on the bucket/basket of the truck that normally flash when switched on from the cab. The wire that runs from the cab to the lights is broken somewhere in the swivel assembly. A swivel is the part on the turntable of the ladder truck where the wiring, hydraulics, and water pipe pass through allowing 360 degrees of turning. The swivel needs to be replaced if we wish to fix this wire. This is not an option at this time due to the cost being over $10,000 to replace with labor.
Here's the deal: There is still plenty of 12 volt power to the bucket area. There are power leads in the bucket area that have constant 12v power as soon as the vehicle is turned on. This power would work fine, but the lights would constantly flash when the vehicle is on- even if not responding to a fire call. The idea: to have a 12 volt relay mounted in the bucket area feeding off of the constant 12 volt power. This relay can be operated remotely to be turned on and off from the cab via a radio/remote control. The remote control can not be like a garage door opener. It must be able to be hardwired into a common on/off (not momentary) 12volt automotive switch.
Questions:
-Where can I buy this transmitter/receiver combo that works with 12 volt systems on a radio frequency, not infrared and preferrably not a keychain remote.
-How can a wire the on/off 12volt switch in the cab to send this rf signal to the relay from a constant on/off switch? I understand how I could wire a momentary switch into the transmitter by simply using the garage door opener-style transmitter and hard wiring it to a switch. But it must use the trucks existing switch whcih is constant on/off, not momentary on/off. The reason: There are several switches for turning on all of the emergency lighting. All of these switches are tied into one MASTER switch. The firemen simply hit the MASTER switch which feeds power to all of the switches that were left in the on position.
Please, any help is appreciated. I am not an electronics genius so please be specific and use lay terms if possible. Your help is greatly appreciated in advance!
-TONY
Questions:
-TONY
