When I apply power i need the LED to be wait 10 sec & turn ON.Below circuit the LED is always on??
If you leave the DIScharge pin disconnected, then you can tie THRES and /TRIG together and only use one RC pair.Connect the anode of LED to +9v and cathode to R3, so that when the timer is triggered the LED is OFF until the time expires.
Also connect pin 7 to pin 6.
Can you tell me is my circuit ok? Then why on the simulator won't workIf you leave the DIScharge pin disconnected, then you can tie THRES and /TRIG together and only use one RC pair.
Interchange the position of R1 and C2 so the TR and Th are low, not high, when power is applied.Can you tell me is my circuit ok? Then why on the simulator won't work
Is the complete circuit powered from 12V?Why the LED never gets off when feeding from a 12V source?
Not yet because little bit more componentsDid you try it like I showed in post#2?
It will work.
The Whole circuit powered from a 12V source.Still my LED is other way not as your one.I will change that as well.Is the complete circuit powered from 12V?
The LED needs to go to V+ as eTech's and my circuit shows.
Is this a simulation or a real circuit?
