SimonTHK
Hello
So I have a relay that turn on 12 v for a motor. But my program in my Uc kept to fail, so now I sat down and looked for weird things that could happen.
Suddenly once out of many, I see my relay fail. As soon as the Uc has to deliver the signal for the transistor to turn on the relay, the relay makes a small spark inside (between the mid leg and the one that provides the 12 volt.) It doesnt even get to move the relay "middle leg", before it makes a tiny spark, and the circuit fails.
I have a "safety" diode over the relay.
What can cause this? How can I solve it?
https://www.google.dk/search?q=rela...%2F115857%2Fflyback-diodes-and-relays;600;374
Check the link above, the first (good) is the one I use witha 4001. But maybe I should use the others, and does it act like mine does? Since I thought the diode was there for after releasing the power to the coil, and it would make some kinda induction.
Thanks in advance
Thanks in advance
