My PWM code to generate 40KHz seems to have a problem? im using ATmega32
kris_maher
I wrote code to use ATmega32's "Phase and Frequency Correct" PWM mode. The clock speed is set to 8MHz and I wrote the code so that it generates a 40KHz square wave on the PD5 output pin. This is basically for a Ultrasonic project I'm working on.
Here's my code:
int PING()
// Use this FORMULA for TOP:
/* TOP/ICR1 = Clock_Speed / (2 * Prescaler *
Output_PWM_Frequency) */
// Thus ICR1 = 8000000 / (2 * 1 * 40000) = 100
// Make PD5 as output pin
DDRD = 0b00100000;
PORTD = 0b00100000;
// Turn off PWM while we set it up
TCCR1B |= 0;
TCCR1A |= 0;
// Setup the timer --> 16-bit Phase/Frequency Correct PWM mode with Pre-scaler = 1
TCCR1B |= (1 << WGM13);
TCCR1B |= (1 << CS10);
// Setup the Compare Output to be set to toggle mode. See pg.108 in datasheet
TCCR1A |= (1 << COM1A0);
// Set ICR1 so the output toggles at 40KHz
ICR1 = 100;
// Set the Comparator so we're at 50% duty cycle
OCR1A = ICR1 / 2;
When I use my PC Oscilloscope to observe for any waveforms coming out of the Ultrasonic transducer, nothing comes up on the screen.
Now it could be due to:
a) Something wrong with my code. Any ideas?:confused:
OR
b) A battery that's almost out of steam. :mad:I have a regulator circuit that steps down voltage to 5V, for this, I have a 9V rated battery that measures just over 6V with a multimeter.
Thanks everyone..
