Music from Korea
Boncuk
Hi all,
for those of you not yet shaving with a hot soldering iron. :D
Here is a bunch of young and charming korean ladies performing in a very refreshing americanized manner (yeah, yeah yeah). :)
Enjoy
Boncuk
Remark: Copy all five files into one folder and rename from e.g. "[MV] SNSD Gee-001.zip" into "[MV] SNSD Gee.zip.001". The downloaded file might be displayed with your explorer with or without the suffix "zip". If "zip" is not displayed the file type should be displayed indicating a zipped file.
Double click the 001 file to unpack and join the files.
To Hero999,
file size 10MB - upload failed
file size 8MB - upload failed
file size 4MB - upload OK
Regards
Hans
  • [MV] SNSD - Gee-00&#49.zip
  • [MV] SNSD - Gee-00&#50.zip
  • [MV] SNSD - Gee-00&#51.zip
  • [MV] SNSD - Gee-00&#52.zip
  • [MV] SNSD - Gee-00&#53.zip
  • [MV] SNSD - Gee-00&#54.zip
  • [MV] SNSD - Gee-00&#55.zip
  • [MV] SNSD - Gee-00&#56.zip
  • [MV] SNSD - Gee-00&#57.zip
I don't know why, but I am afraid to peek...
If you don't try you won't know. :)
There are no viruses hidden in the files.
I just intended to brighten up everybody's day.
I've not had any luck.
I combine all the files together 7-zip said that the compression method isn't supported.
It looks like I need to try a different program.
Hi Hero999.
I guess I made a small mistake concerning renaming of the files.
The correct name(s) should be "[MV] SNSD - Gee.zip.001" (not "[MV] SNSD - Gee-zip.001") and the following files the same way.
The procedure is now corrected in the intial post. Just replace the second "-" with "."
The double suffix was most probably the reason while the upload has been rejected.
If the files are extracted and combined the file name should be "[MV] SNSD - Gee.wmv" and the file size should be 34,082,788 bytes
Sorry for having stolen your time.
Regards
Hans
I made your correction but I cannot join the files and unzip them.
No, nor could I.
I think you need to use Winzip to open the files.
I don't thing the built-in Windows unziper can handle split zip files. I tried 7zip but that didn't work.
I also tried joining the files using the copy command, after which 7zip opened the archive but it wouldn't let me access any of the files.
I haven't tried it under Linux yet.
I have Winzip but it expects each file to end with .zip not .00x. I don't want to waste more time changing the names of each file to be to xxx.00x.zip.
wouldn't it be easier to upload the file to utube and just provide a link and a warning about the files size ......
It depends on whether the Korean girls are beautiful or ugly. I hope they are beautiful and are scantily dressed.
There are about 20 girls and none of them is ugly. :)
I will follow bryan's suggestion and post a link to youtube.
Trying to unpack the files (7-Zip ver. 4.65) I also received an error message. It probably hasn't been tested thoroughly.
Hans
P.S. In the meanwhile you might want to find an answer to this: What happens if Chuck Norris enters a pond?
Solution: sirroN kcucH semoceb dnop ehT.
Good idea bryan,
I included the "warning" about the file size in my post of Mar 12th already.
To repeat: file size is (uncompressed) 34,082,788 Bytes.
Regards
Hans
Gee. The Korean girls are very cute but maybe are a little too skinny.
I guess they're not skinny but not tall. Koreans are "constructed" a similar way as Thais. The average body height is 160cm. I saw women measuring 145cm.
I don't like the music, it sound too much like trashy pop.
The girls are attractive but are very young, the remind me of a certain member's avatar. :D
Fun to watch but ooohh sooo clueless looking.
:p
A bit thin for me as well. I like them well built and with a spark of intelligence behind the eyes.;)
:p
Hi tcmtech,
having been almost in every country of this globe I found 90% of all females looking clueless. :)
However they'll look different when stripping you down if it comes to divorce. :D
