Multiplex switches
Projects people should not build
1. UPS
They're cheaper to buy although watching a car battery explode is always entertaining.
2. Sms cell phone alarm system
Is leaving a cell phone in your car cost effictive?
3. Remote control switch with 3km range
The posters are always shrouded in mystery. What is a good use of such a device?
corection?
shouldn't that be I= 10/(20+5)?!
It's simple. Consider a 20 kOhm resistor in series with a 5 kOhm resistor, with 10 V applied across them. You want to determine the voltage at the point between them. First thing you do is calculate the current through the resistors:
I = V / R
I = 10 / (15 k + 5 k)
I = .5 mA
Now that you know that, you can calculate the voltage drop across each resistor:
V = I x R
V1 = .5 mA x 15 k
V1 = 7.5 V
V2 = .5 mA x 5 k
V2 = 2.5 V
Reality check: the two voltages should sum to the total supply voltage. 7.5 + 2.5 = 10. If you have more than two resistors, you can just extend this process. Now, work out your voltage drops.
