Multi-Mixed Signals
Mikebits
I want to get some opinions and ideas on this. I have a design that has several signal types. A PSoC micro clocked at 24MHz (digital junk), some very sensitive analog signals (uA) current sourced, and audio at 1W. I have partitioned power with analog and digital, along with grounds. Now my concern is the audio, running class D audio at ~1W. My worry is that the audio may cross over into my more sensitive analog sections. So I am thinking another ground for the audio. What about power (I would hate to use another Vcc supply)?
Your thoughts? Also, audio quality is not key concern.
----------------Edit----------------------------------------------------------------
Forgot to mention, the audio devices are: LT6350 https://www.linear.com/product/LT6350
TPA2013 https://www.ti.com/product/tpa2013d1
Assume there is only one Vcc:
I would add a inductor in between Vcc, and VccAudio . A class D amp will make noise at the switching frequency.
You might put the audio in a corner of the board or make a cut in the ground to try to keep noise with in "audio ground". There will be big currents from the bypass caps to the ground pins on the IC. Also: there should be a LC filter on the output of the amp. Watch ground currents in that area.
Thanks Ron, good suggestions.
There is a demo board for the demo board for the audio IC. Look at the layout! (in the manual)
That demo board provides me some useful info, thanks. I noticed on the demo board that they are driving the PA in single ended mode. In the data sheet they recommended differential input, so I was going to do that, but after seeing the eval board in single ended. Hmm
For only one watt, why risk the noise pollution of class D? Lotsa small BTL amps that will make 1 W out of 5 V.
ak
Well, I am only running 3.3v, but I suppose I could add a 3.3 - 5v converter if the noise is that big of a problem. I have never used the D amps before.
No need. That particular device has a boost converter built-in.
ak
I agree with Analog. One switcher is as bad as another.
Use a ground plane. Make the board a little larger. Look for where the current is flowing. Keep the input and output sections away from each other.
ak
I think you misunderstood me. I chose the class D part because I am running 3.3v, and I could not find a BTL that could provide the audio output I need at 3.3v. So I was saying if I use a BTL device, I could add a 5v converter, but Ron brings up a good point, adding more noise again. Thanks
