MPLAB simulation help
yohanevindra
im using MPLAB for my PIC projects, and I also have Proteus. The problem is that the oscilloscope in proteus doesnt seem to work, which means that i cant see the wave output on pins properly...
ive never used the sim in MPLAB, so how do you do it with tht?i need to ensure i get proper delays or 20ms and 1-2ms for my servo control so i want to check that with MPLAB since i wont hav access to an oscilloscope until after the weekend..
Put a breakpoint on anywhere that you change the output pin and use the stopwatch to time the pulses.
If you want it visually, click View->Simulator Logic Analyser. You can select whichever pins you want by clicking on Channels. You can measure the timing using the cursors function.
But the problem is that you can put only one breakpoint..so basically stop the program at the break point and then insert it for the next half of the pulse?
so basically the Simulator Logic Analyser is a oscilloscope built into MPLAB?does it give real time displays or do you need to pause it to see the signal?
You can also right click on the code before your delay and choose "run to cursor". Then zero the stop watch and right click after the delay code and choose "run to cursor". Then look at the stop watch.
I can put in as many breakpoints as I like. Maybe breakpoints are limited for the hardware debuggers, but not for the sim.
Kind of. You would have to pause to see the data I think. You could also do that by setting a breakpoint.
never tried the run to cursor..must do that sometime..
and i ve never tried the breakpoints with the sim..its always been with the ICD2...
jus finishing off my code and will let you guys know if i mange to get it working
