kira_kame
"MPLAB" + "PIC ASSEMBLY LANGUAG"E + "C++" = I NEED HELP !!!
im working on a project and i need help fast.....
and i got only 72 hrs to do it!!!!!
i have a c++ code then i need to use mplab compiler to inject the c++ code in the p.i.c. ...... ummm bit of a noob here so umm u know ^_^...
so the question are:
1> can u directly insert c++ code sa mplab?
coz my predicament is that a PIC reqs. an asm or assembly code to operate, then some pipz told me u can use C++ (i understood c++ more than asm), and then i recently aquired a code fitting for my project and i need to inject that code somehow in my PIC....
2> do i need converters to do this?
some said, they make codes in c lang. then converters to asm then embed the code in mplab to recompile as asm ready for insertion for the pic through serial port or somthing......
3> if 1> is yes :. how to do it???? (same with 2>)
4> if u can do "1>", does it require certain conditions or special syntax? im just wild guessing...
im in a dire pinch so any help will do.... ^_^
(my code is fine thing is i need it "in" the microchip..... YORoSH KU!!!!)
