motor encoder wiring
hi guyz!!..........i have a dc motor with encoder on it but i dont know the wiring of the encoder and the part no of motor and encoder is also not there can any one tell me the which wire is for what purpose ??? it is a 6 wire encoder..
This is pure guess and speculation on my part. Most of these small DC motors used in robotics and other task are similar. So let's try something. Hopefully you have an ohmeter.
I see your red and black wires connected to the motor independent of the connector. Those are likely the motor power. You also have a red and black on the connector. See if they are in fact the same points electrically. Measure from the red independent to the red on the connector. Are they the same point electrically measuring less than an ohm? Now do the same for the black leads, are they the same? Should this be true it's a good start. So:
Red + Motor Power (could be 6 to 12 volts DC) actually I haven't a clue).
Black - Motor Ground
Green = Encoder ground
Blue = Encoder power supply (3.5-20 V) again a guess here.
Yellow = Encoder A output
White = Encoder B output
Most of these little motors use a Hall Effect Transistor output. The A and B encoder outputs are used to determine the motors rotational speed as well as direction. The encoder outputs will be pulses around the DC level of the encoder power supply voltage and one output will lead the other by about 90 degrees. So if output A leads output B by 90 degrees rotation might be CW (Clockwise facing the shaft) or if B leads A the reverse would be true.
Next, that motor has a large head on it lending me to believe it has a gear head. So the actual motor shaft speed is not the output speed. This is where you need to know the gear ratio. For example the rotation of a magnetic disk at the back of the motor shaft signals the hall effect transistors. This Hall effect encoder has a resolution of 48 cpt for the motor shaft, which results in 1633 cpt for the output shaft. Just depends on the gear ratio which must be determined or known. The CPT is the Counts or Pulses per Turn. Having the actual manufacturers part number and name would be a big help. Look for any reference to a gear ratio, anything at all on the motor?
Again, this is a very rough guess on my part but where I would start. The A and B outputs are encoded outputs so then they must be decoded to use the information they provide.
Ron
