MOSFET and Diode ratings
shraddha17
Im designing 3phase vsc (voltage source converter) and I want to know the exact ratings of the power MOSFET and diode for 3phase induction motor of ratings 1500rpm, 440v, 2 hp.
Super Moderator
Most Helpful Member
I have moved your posts to their own thread - DO NOT HIJACK other peoples threads.
ronsimpson
Most Helpful Member
Need help as soon as possible
You are in trouble. lol
If you know enough to build, you should know how to find the voltage across the parts. The power line can have spikes so you will need more voltage rating.
You need to find the current for a 2hp motor. There is run current and startup current. Remember; if you use a part at its rated current it will be hot.
MikeMl
Most Helpful Member
You need a lot more help than a hobbyist forum can provide.
crutschow
Most Helpful Member
As a start you need to calculate the maximum motor current.
Do you know how to do that?
What is a voltage source converter?
What is the source voltage?
If you don't understand the basics, then MikeML likely is correct.
EE World Online Articles
Loading
