MMC write cycles
Scarr
I beleive MMC has a write endurance of 300,000 write/erase cycles.
But what does this exactaly mean?
In other words if I write 1 byte to the following addresses 0,1,2,3,4,5,6 etc in a MMC and I get to address 300,000 will it stop or if I write 1 byte to address 0 300,000 times then address 0 will fail but all other will be OK
Well, for a start - what's an 'MMC'?.
Presumably it's some kind of EEPROM memory?, in which case the endurance figures they give are a minimum figure anyway - a typical device should easily exceed that.
As to what happens when they fail, I've no idea, I imagine it could well vary from device to device - but I would suspect it probably applies to a single byte.
hi every body
can some body help me aboaut mmc that it write protected?????
(surry for my english)
I think he meant to say "MLC", or 'multi level cell'.
hi every body
Multi Media Cards can NOT be used that way. they actually only have 1K to 10K write cycles in them. the outlandish claims are approximations assuming typical use and controllers' wear leveling and real time bad block mapping.
