MMC initialization steps (via SPI)
vinodstanur
Pls give me some working mmc initialization steps;
I tried CMD0 at first and got response 0x01 . But then i give CMD1 but not getting response!=0. Tried in loop untill the response !=0. But not getting response. Tried another MMC .Still same problem. Then i give command(16,0,512,0xfF)//CMD16
But not getting response 1;
Then i had given command(17,0,(512),0xff);//write enable command CMD17
The I could receive 0x05 as response!!!!!!! So i am getting some response as correct. So what is my problem? I think its initialization problem. So any one could give me the correct initialization steps?
Maybe this will help...
You have to initialise the MMC to SPI mode
nt mmc_init()
	DWORD i;
	/* Generate a data pattern for write block */
	for(i=0;i<MMC_DATA_SIZE;i++)
		MMCWRData[i] = i;
	MMCStatus = 0;
	IOSET0 = SPI_SEL; /* set SPI SSEL */
	/* initialise the MMC card into SPI mode by sending 80 clks on */
	/* Use MMCRDData as a temporary buffer for SPI_Send() */
	for(i=0; i<10; i++)
		MMCRDData[i] = 0xFF;
	SPI_Send( MMCRDData, 10 );
	IOCLR0 = SPI_SEL; /* clear SPI SSEL */
	/* send CMD0(RESET or GO_IDLE_STATE) command, all the arguments
	are 0x00 for the reset command, precalculated checksum */
	MMCCmd[0] = 0x40;
	MMCCmd[1] = 0x00;
	MMCCmd[2] = 0x00;
	MMCCmd[3] = 0x00;
	MMCCmd[4] = 0x00;
	MMCCmd[5] = 0x95;
	SPI_Send( MMCCmd, MMC_CMD_SIZE );
	/* if = 1 then there was a timeout waiting for 0x01 from the MMC */
	if( mmc_response(0x01) == 1 )
		MMCStatus = IDLE_STATE_TIMEOUT;
		return MMCStatus;
	/* Send some dummy clocks after GO_IDLE_STATE */
	SPI_ReceiveByte();
	/* must keep sending command until zero response ia back. */
    	i = MAX_TIMEOUT;
	do
		/* send mmc CMD1(SEND_OP_COND) to bring out of idle state */
		/* all the arguments are 0x00 for command one */
		MMCCmd[0] = 0x41;
		MMCCmd[1] = 0x00;
		MMCCmd[2] = 0x00;
		MMCCmd[3] = 0x00;
		MMCCmd[4] = 0x00;
		/* checksum is no longer required but we always send 0xFF */
		MMCCmd[5] = 0xFF;
		i--;
		} while ( (mmc_response(0x00) != 0) && (i>0) );
	/* timeout waiting for 0x00 from the MMC */
	if ( i == 0 )
		MMCStatus = OP_COND_TIMEOUT;
		return MMCStatus;
	/* Send some dummy clocks after SEND_OP_COND */
	SPI_ReceiveByte();
	/* send MMC CMD16(SET_BLOCKLEN) to set the block length */
	MMCCmd[0] = 0x50;
	MMCCmd[1] = 0x00;  /* 4 bytes from here is the block length */
	/* LSB is first */
	/* 00 00 00 10 set to 16 bytes */
	/* 00 00 02 00 set to 512 bytes */
	MMCCmd[2] = 0x00;
	/* high block length bits - 512 bytes */
	MMCCmd[3] = 0x02;
	/* low block length bits */
	MMCCmd[4] = 0x00;
	MMCCmd[5] = 0xFF;
	if( (mmc_response(0x00))==1 )
		MMCStatus = SET_BLOCKLEN_TIMEOUT;
		return MMCStatus;
	SPI_ReceiveByte();
	return 0;
Ian
