OKHi,
As others have mentioned you need a resistor that can handle the power. I meant to say something about this but i had to do something yesterday and could not get back soon enough. Story about this nutty adventure at a later time
Anyway, a resistor has a Ohmic value like 100 Ohms, but it also has another 'rating' or rather specification, and that is the power handling capability. The resistor must be able to handle the power developed in it due to the voltage across it or the current through it.
Knowing the voltage across it we get the power from:
P=V^2/R
where V is the voltage in volts and R is the resistance in Ohms.
Knowing the current through the resistor we get the power from:
P=I^2*R
where I is the current through it in Amperes and R is the resistance in Ohms.
So you can use either of these, and it is quite easy to do.
For example, say you have 10 LEDs in series each 3.2 volts. That's ten times 3.2 equals 32 volts. With a resistor of 100 Ohms, the power would be:
P=32^2/100=1024/100=10.24 watts.
To get a more safe value for the power we would double this, and that would mean we'd need a 20 watt resistor at 100 Ohms.
Doubling the power rating means we get a resistor that runs cooler, but going even higher like 4 times the rating means an even cooler running resistor. Of course this assumes that the resistor gets fresh air through vent holes in the case of the unit it is installed inside of. If there is no fresh air supply then other means have to be employed such as heatsinking to the side panel or something like that.
Lets see if I have this.
My Constant current driver provides 350mA (50mA of which I want to shunt off) and 12 Watts
The LED series string measures a voltage of 29.5 VDC when powered.
The LED's have a forward amperage of 300mA
That means I need a resister ohm value of (29.5 / .05 = 590 ohms) 590 (or 600 for round numbers ?)
To get the wattage it must be able to take I calculate;
(V^2 = 29.5 x 29.5) = 870
and so P = 870 / 590 = 1.47….. or 1.5 watts (rounded)
To be safe means a 590 (or 600 rounded?) ohm 3 watt resister (with air circulation).
If I can locate a 600 ohm resister 3 (or higher?) Watt and plug that in parallel I should be able to end up with 300 mA's running through the LED string and 50 mA through the resister. right?
As my constant current driver is a 12 watt driver and I am trying to run 12 x 1 Watt LED's will the resister reduce the wattage to the LED's?
If so then (and I think I've got it
Damn, I wish I had stayed and finished at Devry 35 years ago…
