MAX220CPE+ for UART application
electroRF
I'd like to communicate between PC and PIC18f4520, and need MAXIM-232 for the voltage levels convertion.
Maxim offers MAX220CPE+ samples, and I'm wondering if it can be used for such UART application.
I'd appreciate your comment regarding that.
Thanks.
electroRF said:
...I'd like to communicate between PC and PIC18f4520, and need MAXIM-232 for the voltage levels convertion.
The PIC18f4520 already supports RS-232.
As would most PCs. If not, a simple USB to RS-232 converter would suffice (in most cases).
Or am I missing something?
Hi bob,
My concern is that the PIC outputs 0V and 5V RS232 signals, while the PC outputs -12V and +12V RS232 signals.
Therefore, I'm afraid I cannot connect the pic directly to a PC.
You see the problem?
i think he means the voltage level shifter like a max232, the one you have linked too should be fine dosnt look much different from max232. somewhere on here is a post telling you how to do it with just resistors i have never tried that tho
Thanks.
hi RF,
The MAX220 is a low power version of the MAX232 and is OK to use as a PIC to PC RS232 level shifter, use the correct capacitor values for the MAX220.
E.
hi Mr Gibbs
OK.
Yes, it can be used for a translation such as you are considering.
I think you might find it more convenient (and cheaper) to use a device like this:
($2.21USD. Not many left...)
Which uses this chip:
Unless, of course, if your PC has no USB port(s).
(This is what I had in mind in my 1st post)
