Math function in assembly
Raju C
can any one help me to write code for this ..
DEC2HEX(MOD(N,1024)+16384,4)
DEC2HEX(INT(N/1024)+17408,4)
FOR MOD FUNCTION I CAN WRITE BUT HOW TO WRITE FOR DECIMAL TO HEX I DONT KNOW .I AM USING PIC 18F AND I HAVE TO PUT THIS FORMULA IN LOOP BCZ HERE N VALUE I AM CHANGING FREQUENTLY..IF YOU GVE ANY HINT ATLEAST I WILL BE VERY THANK FULL
Nigels has some code that show you how it dose DEC to hex you can find it here
Here the part that converts
;This routine downloaded from http://www.piclist.com
Convert:                        ; Takes number in NumH:NumL
                                ; Returns decimal in
                                ; TenK:Thou:Hund:Tens:Ones
        swapf   NumH, w
	iorlw	B'11110000'
        movwf   Thou
        addwf   Thou,f
        addlw   0XE2
        movwf   Hund
        addlw   0X32
        movwf   Ones
        movf    NumH,w
        andlw   0X0F
        addwf   Hund,f
        addwf   Hund,f
        addwf   Ones,f
        addlw   0XE9
        movwf   Tens
        addwf   Tens,f
        addwf   Tens,f
        swapf   NumL,w
        andlw   0X0F
        addwf   Tens,f
        addwf   Ones,f
        rlf     Tens,f
        rlf     Ones,f
        comf    Ones,f
        rlf     Ones,f
        movf    NumL,w
        andlw   0X0F
        addwf   Ones,f
        rlf     Thou,f
        movlw   0X07
        movwf   TenK
                    ; At this point, the original number is
                    ; equal to
                    ; TenK*10000+Thou*1000+Hund*100+Tens*10+Ones
                    ; if those entities are regarded as two's
                    ; complement binary.  To be precise, all of
                    ; them are negative except TenK.  Now the number
                    ; needs to be normalized, but this can all be
                    ; done with simple byte arithmetic.
        movlw   0X0A                             ; Ten
Lb1:
        addwf   Ones,f
        decf    Tens,f
        btfss   3,0
        goto   Lb1
Lb2:
        addwf   Tens,f
        decf    Hund,f
        btfss   3,0
        goto   Lb2
Lb3:
        addwf   Hund,f
        decf    Thou,f
        btfss   3,0
        goto   Lb3
Lb4:
        addwf   Thou,f
        decf    TenK,f
        btfss   3,0
        goto   Lb4
        retlw	0x00
then use a table for the hex letters maybe nigel will tell you more
thank you sir .. But as i am bit new to this so i am not getting exactly so.. will you pls explain me just by giving one example to LB1 loop i will do further ..
thank you sir.. but as i am new to this so not getting exactly so will you pls explain Lb1 loop with one example further i do ..
