Making an Avometer "multimeter" (AC & DC) with some filters
Salam alaikum (peace upon you)
Could I have any help in that project?
Build a digital Multimeter using Arduino.
• The device should be able to measure the following:
1. Voltage range [ -9 V, 9 V ].
2. Current Range [ -0.5 A – 0.5 A].
3. Resistance Range [ 50 Ω – 100 kΩ].
4. Can detect voltage and current frequencies up to 500 Hz only “Greater frequencies should be attenuated by 3rd order filter”.
Device sensitivity in each measurement mode should be calculated.
Even more;
Resistance range [10 Ω – 100 MΩ].
• Connectivity Test Feature.
• Measure the frequency of the input voltage and current signal.
Mainly, I have two problems
1) how to do the idea?
2) the circuit collapse after connecting
1) Accuracy of measurements desired ?
2) Resolution of measurements, V and I
3) Peak, Average, or RMS of AC inputs ?
4) Desired display to be used ?
5) Input Z of meter desired ?
6) Is this a school or class project for a course ?
Regards, Dana.
By calculate the difference between the simulation on spice model and the output values from the real circuit
2) Resolution of measurements, V and I?
I don't know , but could be 0.1 or 0. 01
(any reasonable value)
Could you suggest a AC input method, until now I don't know
16* 2 LCD
Expaine that point please
Project
** picture for the suggested circuit on spice program
Really, thanks a lot for that nick link, it's very helpful, I will try it.
I found for the ohm meter that nice link, also from the same website
Could you recommend an arduino Autoranging AC - DC ammeter?
I found some ideas, but not in my scope : like using sensor or make complex circuits or no give negative current value (only measures positive value, and I need negative value also)
Do you know any helpful link about making number (4) in requirements?
#4) I like the blue mode 16 x 2 or 4, 20 x 2 or 4. They are great displays
readability wise in daylight. Ebay, Banggood sell them. You can get
buss versions (4 or 8 bit) or I2C versions, and google driver for Arduino
several driver libraries available. Or use OLED, 4 color.....
Current -
Regards, Dana.
Thanks a lot, but I mean by number (4) that point
: Can detect voltage and current frequencies up to 500 Hz only “Greater frequencies should be attenuated by 3rd order filter”.
* for the current sensor, I want to the circuit myself, not pay a sensor. The circuit which I make should measure -ve and +ve in range [ -0.5 A – 0.5 A].
