Making a displayless 24h timer for an alarm.
varkunus
Hello I am new to these forums, and am in the stages of designing a circuit for my school gcse electronics project. I am trying to make a safe alarm which is triggered by a passive infra-red sensor, or possibly a micro switch. But I would like this alarm to be fully automated for the owner, and so once they have calibrated when working hours are finished (eg 5pm) and when they start (eg 7am) the alarm will be activated. This alarm when triggered will then spray a fine mist of smart water on the user and the items stole aswell as a siren and flashing lights (astable).
So far I have discovered that a 555 timer will not be accurate enough as it will be loosing upto 15 minutes or more day. So, so far I have have investigated using a 4060 counter, and a 4040 ripple counter in conjunction with a quartz crystal. So I was just wondering if anyone could shed some light on the subject of how to make the timer circuit which can then be used in conjunction with an AND gate. Once of the inputs being the users key card to activate the alarm, the second being during the designated time period.
Anyway thanks for the help guys.... hope I you guys can because I am having problems. Also i would like to avoid using a PIC chip unless it is absolutely necissary.
Is there any particular reason why you do not want to use a PIC? i.e. no programmer, no software developing software or lack of experience?
Many a circuit can be found using PIC's for the desired application and I think that the timer resolution would be much greater than using discrete components.
BTW. Can you please indicate where you are from? It can make helping you much easier.
im from england, i thought from the GCSE bit most people would work that out. Although in south africa its proberly not a common to hear about. Anyway the school has a PIC controller etc, and I was just talking more to my teacher and he said that it might be the route to go down. But i need to make a circuit which is sophisticated enough to get marks for A and A*. Anyway the program at school is PicAxe, if someone could find me a flow chart for a 24 hour clock on there website (google it) that would be great.
Thanks again guys I can see this forum is going to be of great help
One way would be to use an LED clock chip such as the LM8560. You'd have to figure out which digit outputs you'd need to look at for controlling the alarm. You'd probably need a display for setting the clock though.
Or you could just buy an LED alarm clock and use the parts in your project.
I really need to avoid using parts if i can, it gets marked de-ducted. Anyway could someone help me with PIC programming uses flow charts
You should be able to figure out a flowchart on your own. That is what the project is about. To show what you know. Not what you can get us to do for you.
There are numerous examples of digital clocks using PIC on the web. I think Microchip may have an appnote on the subject. Once you get the clock working the rest is easy.
no i dont want you guys to do it for me, just was looking for a point in the right direction in PIC processing. What is microchip? A peice of programming software for PICs? SImilar to PicAxe?
MicroChip are the company who make PIC's. A PICAXE is just a PIC pre-programmed with a BASIC interpreter, so it's limited and slow - but easy to use and cheap.
Welcome to the forum!
If you google "microchip pic", all will become clear.
You still haven't filled in your location in your User CP. You can't expect international readers to guess where you are from based on locally-used terms buried in your posts. I happen to know what GCSE means, but I suspect the term would draw a blank stare from the vast majority of non-English people. ;)
Torben
Do you definitely need this 'out of hours' function? Using a PIC is probably way out of the specifications of GCSE projects. Indeed, microcontrollers are only just covered in A level. When I did mine, albeit many years back, I used two 555 timers for a similar project.
In my circuit I had one 555 as an astable to drive two flashing LEDs which indicated the alarm was 'armed'. I used another to drive a speaker to generate the 'alarm' noise when a reed switch connection was broken. The on/off for the whole circuit was a key switch from Maplin.
For other posters.. GCSE only just covers the basics of a 555 timer circuit. There is a lot of emphasis on other aspects, e.g. explaining in the report how an R/C circuit works and making a pretty 'product' for the customer. You can get almost 100% from two 555 timer circuits and a good report ;)
Can you think of any other functions that you might like to add which are simpler than relying on time of day? Perhaps we could help with that instead.
Um, Never mind Blueroom beat me to the punch.
right well the deadline is the 11th of March and that include making time. I will need to have done the programming but the end of the school year (september). I was also talking to my teacher, and he said I can use a PIC chip. Bear in mind (dont want to sound cocky) but I am proberly the top student in my class so I am looking for something very close to full marks. By the way, the exam board we are on is quite harsh on marks. I was reading through the PicAxe instruction manual and using a flowchart (which can then be converted to basic, a easier way I know) it didnt seem to complicated. So its not like I have to learn to right basic, but i just have to be able to use a flow chart, which can then be coverted into basic and stored on the PIC chip.
It is very good news that you are starting now and have enough time.
The process of making a flow chart and converting it to basic is programming. Yes you will be learning to program. The key is that you do not expect great things the first time you touch a keyboard. First you learn to turn on a LED. Next you make it blink. Then you make several blink. Then you blink them in fun patterns. If you can turn on a LED you can start a motor or open a solenoid. After a while you can control most anything. Anyone here who programs can tell you it is FUN. Even getting that first LED to turn on is a rush.
I have helped several people your age to learn programming. My oldest student just finished his first year of computer science at the undergraduate level.
Rather then think of this as a one time project you may want to think of it as the first step. It can be a very interesting hobby, for some it develops into a career as an electrical engineer or computer scientist.
There are a number of people here who are expert programmers and provide programming help to people on a regular basis.
You can go with a PIC or a PICAXE. I do not know if anyone here is using the PICAXE. PICS are much less expensive and more powerful. Some people here program in Swordfish Basic (free student version) which runs on the 18F family of PICS. Another member has a kit called the junebug. It is a combo programmer/tutor board and would be a great place to start with the project. The tutor part uses the PIC18F1320 which could work as the PIC to control you project. I use it in my class. You can get them as a kit or assembled. You can find them at blueroomelectronics - Smart Kits Build Smart People
well i think the school can only use PicAxe (software). And they have all the adapters and stuff for it. So basically i need to make a 24 hour countdown, which then goes to a reset pin and does the sequence again. But I was the user to be able to program the chip, so they press it once when there working hours finish, and once when there working hours start. And then the chip will remember this and continue to repeat to arm the alarm between these times. Also I have had past experiance with html, and some dos programming. Although it was nothing sophisticated just some basic stuff. So could someone point in me in the right directions of what steps I would need in my program in order to allow the user to choose the times the alarm is armed by.
