This is not for the unexperienced. And may be dangerous to people which have not worked with high voltage. Try this trick. Place a 1/4 watt 10 meg carbon resistor in series with another resistor of higher wattage of around 100k in series with a high voltage power supply. Put an ammeter in series, (this will be your current to figure the value of resistance you will ultimately have) but make sure it is on the ground side of the circuit where the 100k resistor is, and the high voltage power supply can be grounded on that side. When the current lowers to the value to which calculates to the ohmmage you need, remove the high voltage from the circuit. (The current you need to make your resistor R=E/I). But you need to know the voltage supplied by the high voltage supply. It may be beneficial to arc the connection by touching the h.v. source and drawing an arc to limit the current, then get closer as the current decreases. The 100k resistor is only a precaution. To be extra safe put some plexiglas over the components in case of minute flying debree.
