Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
You have pulled a symbol out of the library which has no underlying model file or subcircuit.
You have several choices:
Use the "parameterized" Universal OpAmp symbol. It has Vdd and Vss pins. This is near where you grabbed the one you used. It defaults to a high-performance, rail-to-rail, modern opamp; much higher performance than "old" opamps. You can consider it an 'Ideal" opamp.
Choose a specific OpAmp among Linear Technology's library. Unfortunately, there are no 741s, LM358s, etc.
If you want to model a specific non-LTC product, you will have to learn how to find a model on the web, and import that model into LTSpice. I'm not going to repeat how to that here. The process is well documented...
here is a 741 with same components as per your schematic.
sisiouadial wave for at 1khz amp = 1v
using TINA. it has an ossi scope as well as signal analyser, XY recorder etc.
I like TINA for some things.
raise the dc level and wave gets more curve.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
