Low voltage wifi relay
Extras
I am looking for a low voltage wifi relay to connect the Aquastat line from my hot water tank to the Argo box. We have a ski house and unless I disconnect the Aquastat line from the Argo box (stop calling for hot water) it drains our oil. I was hoping to find a "wifi switch". It only needs interrupt connectivity not supply power. Thanks, Mark
Depends on your electronics skill, an esp8266 module can be setup to give you a logic one via wifi, but you'll need an amount of knowledge and a solder iron.
I don't think that's what I'm looking for. That will turn the power on and off via wifi. I'm looking for some thing to interrupt a circuit and restore the circuit using wifi.
So, you're looking for something with a generic relay contact output? External 5V or 12V wall wart power, USB cable power, etc?
ak
yes but not as a wifi relay, its a json interface intended to work with thingspeak.
