AdamMortlock
Hi guys,
Warning! I am no Electrical wiz!
I am a (BA) Product Design student studying at the University of Derby. I am currently going through my major project research module, I have evaluated the market and found a need for an automatic light switching device between two different LED’s (mimicking a car full beam/ dipped beam light setup) I want this product to automatically do this through the sensing of its surroundings.
I have done research into Photodiodes, Accelerometers and Reverse-Biased LED’s, I want to be able to make this product change through either the monitoring of the light using a reversed biased LED (to know when a car’s lights are coming towards it, or going into street lit areas) or the use of an Accelerometer to monitor movement in the surrounding area for objects moving faster or slower than the cyclist, but not stood still. I will be running this product from a set of rechargeable batteries (early on in the project so not sure specifically on types Li-on most likely, something giving around 2300mAH)
As I say I really have little experience in this (If any), I hope someone could give me help/ advice in what is realistic in a solution for this project, I understand I have not given much to go off. Obviously the smaller and lighter the solution the better.
I will check back on here very regularly (every couple of hours) and look forward to see what you all know! Please if I am going completely up the wrong street with the technology I have already looked into or this is an unrealistic project please tell me!
For a bit of inspiration: https://www.kickstarter.com/projects/1670187625/seesense-the-intelligent-bike-light-with-road-sens this is a light that is a more complex version of what I am trying to do (I think)
Thanks for your time,
Adam.
Adam.
