looking for a network usb hub
jack0987
I have a belkin network usb hub but it will not work with windows 10. I use it for my printer and scanner.
Looking for something similar that will work with windows 98SE (optional), windows xp, windows 7, and windows 10.
A 4 computer usb switch would work with all 4 OSes but there would be a lot more connecting wires.
Please offer suggestions.
I just used a Raspberry Pi Zero W ($10) to create a print server using CUPS. Following this article, **broken link removed**, it was pretty simple to set up. Adding a USB hub allows it to support more than one printer.
I haven't tried this, but it looks like adding scanner support wouldn't be too difficult. Printing And Scanning From a Distance With Raspberry Pi and Your Old USP Printer.
A Raspberry Pi Zero W, the "official" case, a micro-USB To Go cable and an SD card and you could quickly have a stylish, compact, highly customizable solution for less than $25.
Thank you for the reply. I will study up on this.
For now, a ABCD switch would be easy for me to do partly because I already have one mostly built as an experiment for another project.
However, some information would be helpful.
Near as I can see, The two data wires need to be a twisted pair. Please comment.
Also, what if I wanted to run the wires on a circuit board? How would one twist the wires on a circuit board?
They don't - your premise is wrong - unless your PCB is 100 feet long?.
Do you mean that the traces of the data lines just run along side of one another?
Yes, the twisting is simply a function of a cable, that's all. It's to prevent crosstalk, and each pair of wires has a different twist to help crosstalk between pairs.
On a PCB it might be a good idea to insert a ground track between them?.
Once, I made a PCB where the data traces were about 3 inches long running side by side. It did not work.
So, you think putting a ground trace between them will solve the problem?
This may not work, but it might help solve the problem.
