lm7804 does it exist
SimonTHK
I am looking for an LM to stabilize 4volt. I cant find any datasheets for it...
Also where is best place for datasheets to find?
cheers
No, it doesn't exist so why not use an LM317?
The reference in a LM317 is 1.25V. It has a dropout voltage of ~2V, so if you want to make 4V out of 5V, it will not work. You will have to find a special LOW-DROPOUT adjustable regulator.
can that be very accurate?
A typical adjustable regulator like an LM317 is stable within a few mV over the temperature range, over input voltage range, and over the output current range.
How much current do you need?
If it's just a low current reference, you could use the TL431.
EDIT:
The LM317 has a voltage tolerance of 4%
If you initially trim it to a specific voltage, how stable is it thereafter, based only on temperature, input variation, output load changes?
I wasn't disagreeing with you.
The OP asked an ambiguous question about accuracy so I thought I should let him know the voltage tolerance of the LM317.
