That's kind of like asking which wine tastes best.Hi guys, the title says it all... my projects with LM358s as the chosen op-amp is always frustrating.
Now, my network will contain motors and some noisy stuff, so which part ID is the most suitable as an alternative to LM358s?
The truth is the LM358 and quad version LM324 have probably shipped a billion pieces over the years. They are a good choice for an op amp if you need one that allows the input voltages to go all the way down to ground (or the ngative rail). Their output also swings all thw way down to ground which is not a common feature. They are unity gain stable and pretty tolerant of capacitive loading. They are not a good choice for audio amps or wide band signal processing but they were never intended for that. I have used them dozens of times for various projects.welll... simple operations regarding amplification didn't work, and I did a little bit fancier stuff with my thermal anemometer using TO-92 transistors as sensors... they didn't work too...
Point is that I've heard some grumbles regarding 358s and want to confirm it. Well I got my answer.
Thanks audioguru.
I would wager they are the most commony used op-amp in electronics.I have over 2000 LM358 opamps here and use them for the majority of my project.
Not had a problem with one yet.
Like I said, the LM358 was never intended to be an audio amp and it's also a design that is probably 30 years old. There are now much better op amps available, but they cost more as well. For general purpose work, the 358 has been a pretty solid workhorse.The LM358 and LM324 opamps have a low bandwidth of only 2kHz and 3% of crossover distortion.
The Motorola (ON Semi now) MC33171 single, MC33172 dual and MC33174 quad opamps have exactly the same low supply current, exactly the same minimum supply of 3V, exactly the same inputs that work at the negative supply voltage that can be ground and exactly the same output that goes very close to the negative supply voltage that can be ground.
But they are much better because they do not have any crossover distortion and have a bandwidth to 35kHz. They also have a max supply voltage of 44V which is much higher than the max of only 32V for the National Semi opamps.
