RogerTango
I am starting to work on several LED projects, but the more I get ready to start, the more confused I feel.
I am trying to use LM317 regulators. I read they are both variable voltage, and variable current regulators, depending on the wiring, I feel pretty good on those concepts.
I also read that LEDs are not "light bulbs", and current is applied at required rate, rather than varying voltage. That "seams" to make sense with me.
Now the question is, and this is for the sake of discussion, lets say I have an LED that is rated at 4w forward voltage, and 350ma of current.
Is it reasonable to believe that too much voltage will be bad even if the current is right?
Say I use a 317 to regulate the CURRENT in an automotive situation where the source is 12vdc, then 12v will be delivered to the LED?
What about using two 317s, the first to regulate the current, passed to the second to regulate the voltage??? Or maybe vice-versa?
Or am I not seeing the forest for the trees??
I have been reading up, but Ive not really seen a "Powering LEDs for the super stupid n00b" quite yet.
Thanks for the help in advance!
Andrew
Andrew
