LED Flash light ..Pulsed LED, underdamped oscillations
well i have finished it ,sort of ..
it very well might be the worlds largest shaker generator..
it is presently getting a little over 300mA .. i've maxed out my little analog meter , (250 mA max).. lol
i have increased the current output by eliminating the dead spots in the output wave..
Why did you use so many turns on your coils that the voltage is way too high? After shaking for several seconds the 5700uF cap charged to 30V will power an LED through a 1k current-limiting resistor for only about 10 to 15 seconds. You need to use a constant current source or PWM to keep the LED from dimming as the cap discharges, but 30V is too high for PWM since the peak LED current will be too high.
it is not the number of turns ,per se , that increased the voltage ,in so little time,as much as the transformer i used, but without the increase in the number of coils , the transformer wouldnt have helped..
in fact i used a 2K resistor ..
i will be using PWM and a constant corrent source..
conserving energy
C2 is initially charged to say 30 V..
C1 is 0V..
R1 is 2K ..
LED is a white ~ 3 V forward voltage drop..
when switch is thrown C1 charges up to C2 voltage minus the LED diode drop..
But the beauty of this configuration is C1 still has about 27 V in it..
the problem is C1 only took about a second to charge up :( ..
but the energy is still in the system..and the white LED had a respectable 4 mA going through it..
am i just delaying the inevitable?
or can i use the energy stored in C1 to repower the LED later on..somehow??
when i put a 3V lithium battery in place of C1 (same polarity as C1, plus at top ) the led stayed lit for about 7 mins.
only using about 1mA current..
how about using a rechargable in place of the lithium battery or again a super cap. ..??
Only 4mA through an LED for a flashlight?
Those very dim solar garden lights that don't light-up anything are about 4mA, aren't they?
The LED flashlights at the store use 24 ultra-bright LEDs operating at 20mA each. for a total current of nearly 1/2A, from 3 or 4 D cells.
That's what is called a flashlight. What's yours called? He, he. :lol: :lol:
Well , when their flash light batteries burn out mine will still be going..
ps got a link to that light mentioned??
You cod put in a seting of brightnes.
Soyou can have high brightnes and les on time and low brightnes and more on time
exactly ,
now i have to brush up on my pic PWM
You can also use ADC to make it in an constant curent surce. and an nother ADC to conect an potencimeter to set the brightnes
this is how i was able to get over 300mA ..
scope is set @ 5V /div 20mS /div..and scope is connected directly across the bridge rectifier and a high value resistor to cut down on ripple from the diodes..and without the transformer connected..
Out of 180 mS , two passes , 140 mS or so , of it , is a non zero value.. :D
I see a peak of 15V, an average of about 6V and hardly any current into your high-value resistor. How did you connect a current meter to measure 300mA?
Hi Willi,
Don't give up!
Maybe you could use 3 or 4 shakers as pistons in an engine, driven from a crankshaft. Then use one of your small windmills to spin it and it should create enough electrical energy to light a few LEDs brightly.
The reciprocating shakers would waste mechanical power, so maybe a smoothly rotating generator is best. :lol:
i ordered (10) .22F super caps last night . At 5.5V they could hold 33J energy..
Below is a charging curve for one of the 1F caps i believe..so the actual charging time will be less per cap but i have 10 so i figure 30 or 40 seconds of shaking should charge them ..
