prenavin said:
I want to get 60mA through them when connected directly. So that when i multiplex them by 6, the average current will be 10mA.
You are confusing series and parallel. If you chain them all together end to end, then they will all have the exact same current which the resistor does. If, on the other hand, you connect them in parallel with all anoces connected to each other, and all cathodes connected, then each one will use a fraction of the current coming through the resistor.
And as everyone else is saying, yes, you will see all the magic smoke coming out of your diodes if you put 60mA through them.
