LCD Frequency Meter
InfernoJaffa
Hi everyone!
I have a project that i need help on starting.
I have a flow transducer that outputs a frequency range which changes at different water flow rates.
I would like to convert this frequency output into a litre/minute calculation on a LCD display.
I am a novice, any tips or directions? Any help is welcome!
If you check the EPE website, they have published a number of counter projects, or MicroChip have an appnote for a frequency counter.
Hi Nigel,
Thanks for your reply, I have looked at the microchip appnote using a PIC16C54 and found that the source code snippet is written in assembly language. I have done little assembly at college but feel that the C language would be a wiser choice for me. I also tried searching for the EPE website you had mentioned and found a site called EPEMag, was this the one you meant? I couldn't find much on that website.
I have found other projects using an Atmel chip with easy to understand source codes although programming the chip will not be easy. I would like to design the PCB board to include on-board programming as this will be easier to reprogram in the future (this should be a simple addition at the end).
The PIC chips I used at college were PIC16F84A and were programmed in assembly language.
Edit: I have learnt that I can connect the frequency directly to timer1 and measure the counts over a 1 second period. I can then take the value from timer 1 and calculate and display the flow rate.
I have attached a flow chart of what I would like the PIC to do.View attachment 61806
Can anyone suggest a good PIC to use, I have found the PIC 16F874 with Timer1 function although it seems to have more features then I need (40Pins).
Can anyone tell me the difference between these two PICs:
PIC16F887-I/P 20MHz - £1.89
PIC16F877A-I/P 20MHz - £4.09
I have chosen the PIC16F877A but in terms of cost the difference is 'noticeable'.
The 877A is a very old device, similar to the 16F84A - modern devices are MUCH cheaper, presumably to encourage people to stop using the antique ones :D
Presumably the 887 is the modern replacement for the 877?.
Thanks for confirming this, so I should be fine in using the newer chip as a replacement without any issues?
