LCD display
If writing 8 bits is the problem then a write nibble function should solve it,
[COLOR="Blue"]void LCD_nibble(unsigned char nibble){
    LCD_CTRL_PORT &= ~(1<<LCD_rs);
    LCD_DATA_PORT = (nibble & 0xF0)|(LCD_DATA_PORT & 0x0F);
    LCD_enable();
}[/COLOR]
void LCD_init()
   //initialize LCD control lines
   LCD_CTRL_PORT &= ~(1<<LCD_rs);   // RS low
   LCD_CTRL_PORT &= ~(1<<LCD_rw);   // R/W low
   LCD_CTRL_PORT &= ~(1<<LCD_en);   // E low
   // initialize LCD control lines to output
   LCD_CTRL_DDR |= (1<<LCD_rs);
   LCD_CTRL_DDR |= (1<<LCD_rw);
   LCD_CTRL_DDR |= (1<<LCD_en);
   // initialize LCD data port to input
    LCD_DATA_DDR |= 0xF0;// Data on high four bits of port
[COLOR="blue"]    _delay_ms(15);		//start of required sequnce
    LCD_nibble(0x30);
    _delay_ms(5);
    LCD_nibble(0x30);
    _delay_ms(1);
    LCD_nibble(0x30);
    _delay_ms(1);
    LCD_nibble(0x20);		//switch to 4 bit mode[/COLOR]
   LCD_start();
   LCD_function_set();
    _delay_us(40);
   LCD_display_off();
   _delay_us(40);
   LCD_display_clear();
   _delay_ms(2);
   LCD_mode_set();
   LCD_display_on();
The blue bits are the changes from your original code.
thanks a lot, at last it works!
keep up that good work!
