t.man
If writing 8 bits is the problem then a write nibble function should solve it,
Code:[COLOR="Blue"]void LCD_nibble(unsigned char nibble){ LCD_CTRL_PORT &= ~(1<<LCD_rs); LCD_DATA_PORT = (nibble & 0xF0)|(LCD_DATA_PORT & 0x0F); LCD_enable(); }[/COLOR] void LCD_init() { //initialize LCD control lines LCD_CTRL_PORT &= ~(1<<LCD_rs); // RS low LCD_CTRL_PORT &= ~(1<<LCD_rw); // R/W low LCD_CTRL_PORT &= ~(1<<LCD_en); // E low // initialize LCD control lines to output LCD_CTRL_DDR |= (1<<LCD_rs); LCD_CTRL_DDR |= (1<<LCD_rw); LCD_CTRL_DDR |= (1<<LCD_en); // initialize LCD data port to input LCD_DATA_DDR |= 0xF0;// Data on high four bits of port [COLOR="blue"] _delay_ms(15); //start of required sequnce LCD_nibble(0x30); _delay_ms(5); LCD_nibble(0x30); _delay_ms(1); LCD_nibble(0x30); _delay_ms(1); LCD_nibble(0x20); //switch to 4 bit mode[/COLOR] LCD_start(); LCD_function_set(); _delay_us(40); LCD_display_off(); _delay_us(40); LCD_display_clear(); _delay_ms(2); LCD_mode_set(); LCD_display_on(); }
The blue bits are the changes from your original code.
thanks a lot, at last it works!
keep up that good work!
