keypad & LCD
dengdiego
does anyone know where i can get a pic basic pro sample to display a key being press then display on the lcd. i'm using pic 18F452 chip to do the job.
thanks a bunch
you hardly need a 18f452 to do that, even the obselete 16f84 can do that and there is plenty of code for that on the web. I would suggest a 16f628 since the code is almost identical to the 84 so you could use most of the samples you find with just a little work.
follow this
you can follow this flow chart...it gave me such a hardtime to finish a project just like yours. so giving you this chart to followe...it helps a lot...study well and good luck..
thanks.
thanks..for the flow chart...it help a lot. if i were to output the key pressed on to the lcd. Can i just set a temp file to stored the key file and lcdout?
thanks
