manba
Hi, there..
I'm designing a 3x4 KeyPad with LCD. I'm using pic16f877a and PICBasic.
The program take the number from the keypad and disply the number on the LCD"Key= num".If no number pressed the LCD disply "Key= 0"
The problem is: only the numbers of the first column are displied on the LCD.
I tried to solve the problem but i couldn't. plz help me.
DEFINE OSC 20
'**** LCD ****
DEFINE LCD_DREG PORTB
DEFINE LCD_DBIT 8
DEFINE LCD_BITS 4
DEFINE LCD_RSREG PORTB
DEFINE LCD_RSBIT 0
DEFINE LCD_EREG PORTB
DEFINE LCD_EBIT 1
DEFINE LCD_LINES 2
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 40
Key VAR WORD
'**** KeyPad *****
TRISD = %11110000
'**** VAR_KEY ****
OLD_RESULT VAR BYTE
KEY_RESULT VAR BYTE
KEYPRESS var byte
FLAG VAR BIT
'**** MAIN program ****
PAUSE 500
LCDOUT $FE,1
MAIN:
CALL MAIN_LCD
CALL MAIN_KEY
GOTO MAIN
'**** LCD Subprogram ****
MAIN_LCD:
Key = OLD_RESULT
LCDOUT $FE,$80
LCDOUT "Key = ",DEC Key
RETURN
'**** Keypad Subprogram ****
MAIN_KEY:
CALL SCANKEY
IF KEY_RESULT = OLD_RESULT THEN MAIN 'same character
IF KEY_RESULT = 0 THEN MAIN 'non is pressed
RETURN ' will replace with (RETURN)
'**** Scan Key Subprogram ****
SCANKEY:
KEYPRESS = 0
PORTD = %0100 ' Chose colum 1
CALL ROW
IF FLAG = 1 THEN FIRST_COLUM
PORTD = %0010 ' Chose colum 2
CALL ROW
IF FLAG = 1 THEN SECOND_COLUM
PORTD = %0001 ' Chose colum 3
CALL ROW
IF FLAG = 1 THEN THIRD_COLUM
KEY_RESULT = 0
RETURN
FIRST_COLUM:
LOOKUP KEYPRESS,[1,4,7,10],KEY_RESULT
OLD_RESULT = KEY_RESULT
RETURN
SECOND_COLUM:
LOOKUP KEYPRESS,[2,5,8,0],KEY_RESULT
RETURN
THIRD_COLUM:
LOOKUP KEYPRESS,[3,6,9,11],KEY_RESULT
RETURN
ROW:
FLAG = 1
IF PORTD.4 = 1 THEN EXIT_ROW
KEYPRESS = KEYPRESS + 1
IF PORTD.5 = 1 THEN EXIT_ROW
IF PORTD.6 = 1 THEN EXIT_ROW
IF PORTD.7 = 1 THEN EXIT_ROW
FLAG = 0
EXIT_ROW:
RETURN
END
