MrDEB
been trying different versions of code to read a DS18B20. The orginal code was using an example from DIY ELECTRONICS. It works w/ a Pickit2 but dang if I can get it working using the Junebug. Is there something I need to do to get it to work?
Here is the code I am trying to use as well as a code that Pommie posted eons ago that does work on the Junebug.
Got to be a reason why one works and the other does not.??
first code is set for an 18F1320 but does not work
The programmer device shouldn't make a difference but??
And yes I doubled checked the baud rate = 9600 in code and USART tool.
Perhaps the clock rate?
This code was posted by Pommie eons ago and it works. BUT why does one that works using an 18F452/Pickit2 but changed to a 18F1320/Junebug.Device = 18F1320
Clock = 8 // 8MHz clock
Config OSC = INTIO2, WDT = OFF, LVP = OFF
//Include "OW.bas"
Include "USART.bas"
Include "DS18B20.bas"
Include "CONVERT.bas"
// import modules...
//Include "DS18B20.bas"
//Include "convert.bas"
//Include "usart.bas"
Include "utils.bas"
// working variables...
Dim
TempA As ShortInt,
TempB As Word
// Start Of Program...
SetBaudrate(br9600)
SetPin(PORTA.4)
// Find() will search the bus for a single DS1820 device
// and load its ROM ID into the DS1820 public variable RomID - you
// could do this manually. For example, RomID = MyRomID...
If DS18B20.Find Then
While true
Convert
GetTemp(TempA, TempB)
USART.Write(DecToStr(TempA),".",DecToStr(TempB,4), " C", 13, 10)
DelayMS(1000)
Wend
Else
USART.Write("No device found", 13, 10)
EndIf
Device = 18F1320
Include "OW.bas"
Include "USART.bas"
Dim Temperature As Word
Dim i As Byte
OSCCON = $72 // select 8MHz internal clock
ADCON1 = $7f //all digital
TRISA.3=0 //A3 output
PORTA.3=1 //and high
SetBaudrate(br9600)
OW.SetPin(PORTA.4)
While true
If OW.Reset Then
OW.WriteByte(owReadROM) //Skip ROM
USART.Write("Rom = ")
For i = 0 To 7
USART.Write(HexToStr(OW.ReadByte()))
Next
OW.Reset
OW.WriteByte(owSkipROM) //Skip ROM
OW.WriteByte($44) //Convert
OW.Reset
OW.WaitForHigh //wait for convert to finish
OW.Reset
OW.WriteByte(owSkipROM) //Skip Rom
OW.WriteByte($be) //Read Scratch Pad
Temperature=OW.ReadByte()
Temperature=(Temperature+OW.ReadByte()*128)
USART.Write(" Temperature = ",DecToStr(Temperature/4))
If (Temperature And 1) = 1 Then
USART.Write(".5")
EndIf
USART.Write("C",13,10)
Else
EndIf
DelayMS (100)
Wend
End
