JuneBug - BS250 orientation
SUCCESS!! (well.. almost)
Top 1/2 of board appears to be working now. Bottom half.. not so much. (No blinky led's). I'm wondering if this may be a problem with my build tools, as they may be trying to link things in a way that would support a bootloader in 0x000 - 0x200. [Something I did for supporting a *different* board]
Too bad "real life" is about to rear it's head for a couple of days.
It is... ALIVE!!! (Bwwwwaaaaa ha ha ha ha!)
PHew... now I'd better back this away before SWMBO sees me still working on it. :D
Thanks for all the consultations!
Great, glad to hear it. What is a SWMBO?
What language are you programming it with? PS the bootloader has nothing to do with the 18F1320 on the Tutor.
I have a different board that had a 18F452 (with a serial bootloader on it). In order to get THAT board to work properly, I had to edit the MCC library files and recompile. Because of that when I first programmed my "demo" code, it picked up those libraries and would not work.
I will have to work out a way to get support for both build environments going.
I'm using C right now, as I'm more comfortable there. With time I can work through the assembly (much like.. with time I can determine the likely BAD component on my board.;)
But I'm workin' my way down.
SWMBO - She Who Must Be Obeyed.. (who likes to refer to me as HWMO) :o
3v0 said:
How do you like the GBDSO? I need to get a DSO of some sort to use at school. Mostly to look at port activity.
As a geeky toy.. it's great. As a useful tool, it's a little on the weak side mostly due to: a. Not very fast, and b. dealing with a 4 button user interface.
Someone was telling me about some newer USB based DSO product out there, in the sub $150 range.
My workbench also has a MINI-LA, and a small JTAG interface as well (can't recall the name). Most home/brew kit type stuff.
Of course... if someone wants to make a cartridge for the Nintendo DS that would do similar functions as the GBDSO.... :D
