JFET
Lalit
Hi all,
In a JFET, why is the magnitude of gate-source cutoff voltage equal to that of pinch-off voltage ? :roll:
Lalit
clarification
Hi pebe,
well there's a bit of confusion here about what i meant to ask.
I do not intend to disrespect your reply.
I just want to clarify the definitions as i have learnt them:
pinch-off voltage is the minimum drain-source voltage at which the drain current essentially becomes constant.
gate-source cutoff voltage is the gate source voltage where the channel is completely cut off and the drain current becomes zero.
plz do correct me if i am wrong somewhere or if there is some conceptual
error.
Regards,
Lalit :)
I have always understood that 'pinch-off voltage' is the often used slang term for the gate-source cutoff voltage.
