is the output of a bipolar 555 large enough to drive a mosfet
user1453
as the title suggests, is the output of a 555 bipolar timer great enough to drive an irf740 n power mosfet.
the application is for a coil gun
do I need to addd an additional gate drive circuit?
The IRF740 and most other Mosfets are spec'd to turn on fully with 10V on the gate. A 555 will give an output of 10V when its supply is 11.3V. Use a 12V supply and it will be fine.
An IRF740 is rated for a very high 400V but fairly low current. Is it useful to drive a coil?
About the curent.....no problem. About the voltage ...the treshold is like 4V max but at 10V RDS(on) is quite small so if u use like 12V for powering the 555...it's the best sol.
watch out for the output sourcing capability of the 555 timer w.r.t. how fast you want to switch the FET
user1453 said:
pulse rated current is 40A
That is the current when a very high supply voltage is used. Its minimum current is only 10A at lower voltages. Its on-resistance is high.
An ordinary IRF540 has a max on-resistance 10 times lower.
You can't buy exactly what you need, so plan on the worst case then all your circuits will work.
however the voltage rating is 1/3rd of the irf740, this would bring the energy stored in the cap bank from 450j to 50j
