As oposed to air? Air is way too compressible to balance out the external pressure at the bottom, yet have close to zero pressure at sea level.Wouldn't that work without filling it with oil?
Ok, good to hear. I'll whack off the tits and post a nude pic.I worked at GE motor factory once in Murfreesboro TN those tips are ejector pin holes for the die cast machine. They are left long for a reason it makes it easy to balance the rotor. Rotors spin in a machine when the red lights comes on the machine stops with the red lights on. Red light lines up with the tips that need to be shorter on the ends.
Read about the Tesla Motor your motor in oil will have oil resistance which will pull extra high idle current when the motor is not under load.
Wouldn't the oil drag be considered a load?
As long as the motor winding are being adequately cooled by oil circulation substantial overload compared to open air operation is not a problem meaning a 10 HP rated air cooled electric motor running submerged in a bath of light viscosity oil can easily take being overloaded to the 20+ HP equivalent input power levels without winding overheat damage.
By machining the rotor down to be as smooth as possible on the exposed surfaces the overall mechanical drag will be greatly reduced. By doing that the main source of drag that will be present will be from simple surface tension between the rotor and the oil.
Taking the fins and stubs off is basically like taking an oar for a row boat and turning it 90 degrees to its normal orientation when it's in the water. Same surface area in contact with the fluid but the ability to transfer mechiacal motion energy to fluid displacement is greatly reduced.
Maybe so but why would anyone want to 3 phase motors are a dime a dozen. The shaft is designed for 10 hp not 20 hp. The shaft is pressed into the rotor it is designed for 10 hp too. The shaft key way is designed for 10 hp. I have seed shafts twisted off, shafts spun inside the rotor, key ways sheared off. Too much torque can break off the motor mounts.
Strantor, did you make the 3D drawings? Pretty nice. Knowing a 3D tool along with your electronics background makes you quite versatile.There's a piece of the puzzle you're missing. I thought I discussed it, but maybe I neglected to mention the integrated accumulator. There's a collapsible bellows exposed to atmosphere which keeps the internal pressure always a few PSI higher than atmosphere via compression springs. Here's some screenshots of my current design. It's rough; I'm not done.
View attachment 98568 View attachment 98569 View attachment 98570 View attachment 98571 View attachment 98572
Bojangles? For this experiment I scraped the bottom of the barrel for the **broken link removed** (and **broken link removed**).Looks professional strantor, I was going to mention lube for the bearings, its going to be much colder underwater and ordinary grease might not do the trick, but I see the internal oil does the job, and no doubt it'll be ok for lubing the 'box.
What make of 'box is it, hopefully not a bonfiglioli.
On a lighter note I've known outdrives run for ages with nothing but seawater for lube when a seal has gone.
Hey, thanks. Yeah I made the drawings in Sketchup. It's the only tool I know, and that's a problem. When it comes time to have these parts made, machine shops are accustomed to having CAD files submitted in formats that translate to their CAM software to be more-or-less directly loaded into their CNC machines. Sketchup doesn't do that. Sketchup is for hobbyists. Solidworks and Autodesk are what the industry uses, and they play nice with the machines. In the past I have had to submit my designs as PDFs with graphical drawings like this:Strantor, did you make the 3D drawings? Pretty nice. Knowing a 3D tool along with your electronics background makes you quite versatile.
Then the machine shop has to re-draw it, or if it's a simple part made on a manual machine, it's good enough for the machinist to just make it.
Last month my boss paid ~$4KUSD for an annual subscription to **broken link removed** for me to use. That's a mammoth package including AutoCAD, AutoCAD Electrical, Inventor, and a few more suites. I'm totally lost in there. I need to attend some classroom training but I don't have time. So far I've only learned enough to get by; I still do all my designs in Sketchup, but now I use a 3rd party plugin to export to *.STL, which I import into Inventor, and then save in Inventor's native format. So far nobody has complained...
Yes I have a test chamber and I hope to test it by friday. It will be tested to 450psi (~1000ft seawater). I have not tested under pressure yet because my bellows compensator was a failure. I have a new compensator design that should be ready by tomorrow.Thank you for the feedback, that is interesting.
Do you have a hyperbaric chamber handy?
It would be interesting to see if the running current changed when the thing was subject to seabed pressure.
Just sitting here I don't see why there would be a significant change, but that is one of those things which is likely to turn around and bite you.
