raedbenz said:ok i have read about SIRC's code..
but i am asking about the hardware that will modulate the IR 38KHz beam with data?? what is the design technique?
raedbenz said:take a look to this website
http://www.rentron.com/Infrared_Communication.htm
they have modulated the 38khz with a serial data using NAND...
have u ever tried that..??
raedbenz said:ok..!
what about receving data ?? do i connect the output of IR receiver to any I/O pin of PIC and decode the binary string..??
Sceadwian said:For receiving it's probably easier to buy an IR receiver module at the carrier frequency you're using, it's a WHOLE lot easier than trying to decode it yourself, and you can feed it directly in a PIC's UART.
raedbenz said:does the RF signals work the with same concept...if i use a FSK or ASK IC??
