Will an induction heater work with 1.5 volts or does it need higher voltage?
I bought four 1GBTs several years ago for H circuit but the project went away now I have a new project. I need information what works best and a target to work for before I start.
Black smith is interested in this project he heats 1/2" diameter solid steel rods red hot to bend into desired shapes. I have several EI transformer lamination that I saved for 1500w, 3000w, 5000w transformer. I hope I can run this circuit on 120vac with output of 1v at 1500a or 1.5v at 1000a.
I can wind and build my own transformer, no problem, I worked in a transformer factory once I have formulas and know how to do it for 100% duty cycle.
I wish I could see the inside of an industrial induction heater, I would like to see how mosfets are mounted and how they are cooled.
Looking at pictures I see the main coil is water cooled copper tubing attached with brass fittings. I assume brass fittings connect to the water cooled heat sinks with 2 mosfets on each heat sink.
Are industrial units water cooled?
