increment/decrement numbers on an lcd
dawson
I have been try the experiments from rajbex and am currently trying to implement his latest experiment into my project.
I want to set a number in the eeprom and can do this thanks to rajbex. however if I want to change that number I am having difficulties.
I have the following code:
  Project Name: Read/Write Internal EEPROM
  * Copyright:
     (c) Rajendra Bhatt, 2009.
 * Description:
     This code is an example of accessing internal EEPROM.
 * Test configuration:
     MCU:             PIC16F628
     Oscillator:      IntRC I/O
// LCD connections definitions
sbit LCD_RS at RA0_bit;
sbit LCD_EN at RA1_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISA0_bit;
sbit LCD_EN_Direction at TRISA1_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD connections definitions
// Define Messages
char message1[] = "1.READ";
char message2[] = "2.INC";
char message3[] = "3.DEC";
char message4[] = "Set Temp:";
char digits[] = "0";
unsigned short  i, NUM ;
unsigned int ADD = 0x00, temp; // Start EEPROM Location
void main() {
CMCON  |= 7;      // Disable Comparators
TRISB = 0x0F;
PORTB = 0x00;
Lcd_Init();
start:
Lcd_Cmd(_LCD_CLEAR);               // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF);          // Cursor off
Lcd_Out(1,1,message1);             // Write message1 in 1st row
Lcd_Out(1,8,message2);
Lcd_Out(2,1,message3);
do {
// Read Operation
if (Button(&PORTA, 2, 1, 0)) {  // Detect logical one to zero
      Delay_ms(300);
      Lcd_Out(1,1,message4);
      NUM = EEPROM_Read(0x000);
      digits[0] = NUM+48;
      Lcd_Out(2,1,digits);
      delay_ms(1000);
      goto start;
 //increment
 if (Button(&PORTA, 3, 1, 0)) {  // Detect logical one to zero
      NUM = EEPROM_Read(0x000)+1;
      EEPROM_Write(0x000,NUM);
      digits[0] = NUM+48;
      delay_ms(1000);
      goto start;
//decrement
   if (Button(&PORTA, 4, 1, 0)) {  // Detect logical one to zero
      NUM = EEPROM_Read(0x000)-1;
      digits[0] = NUM+48;
      delay_ms(1000);
      goto start;
 } while(1);
The above code does work and when pressing the corresponding button the number is incresed or decreased, however I can only display numbners 0 - 9. I am led to believe that the next number 10 is being stored but I need to seperate it and display 1+48 and 0+48. How can I do this? Also I would like to be able to store and display negative numbers as I need a scale of -55 to +125
thanks for the advice I now have it working for +numbers but still having trouble with negative numbers. Also it displays as 001,010,100 etc how can I make it just display 1,10,100:
here is the code i have now:
  * Copyright:
 * Description:
     MCU:             PIC16F628
// Define Messages
char digits[] = "000";
void lcd_convert() {
     // check if temperature is negative
     if (NUM & 0x8000) {
        digits[0] = '-';
        // Negative temp values are stored in 2's complement form
        NUM = ~NUM + 1;
     if (NUM/100)  {
        // 48 is the decimal character code value for displaying 0 on LCD
        digits[0] = NUM/100  + 48;
     else   {
         digits[0] = '0';
         digits[1] = (NUM/10)%10 + 48;             // Extract tens digit
         digits[2] =  NUM%10     + 48;             // Extract ones digit
void main() {
     TRISB = 0x0F;
     PORTB = 0x00;
     Lcd_Init();
     start:
     do {
        // Read Operation
           Delay_ms(300);
           lcd_convert();
           delay_ms(1000);
           goto start;
         //increment
            lcd_convert();
            delay_ms(1000);
            goto start;
          //decrement
             lcd_convert();
             delay_ms(1000);
             goto start;
        } while(1);
Try this.
1. Change unsigned short NUM to signed short NUM.
2. change the following code
else {
digits[0] = '0';
TO
else {
You will still see 0s but you should be able to display negative numbers. Give it a try.
- Raj
Experiments with PIC16F628A
Yeah that and another minor adjustment have solved the negative numbers issue thanks.
Any ideas on how to remove the extra 0's?
I have been exploring and reading up on c programming, but have only been learning a few days and am struggling. I will continue to work on it and read the tutorials you suggested in an earlier post but so far I have not come across anything that will help me here.
