Hey guys.
I am working on a gauge cluster modification in my car and need some help.
Some car gauge clusters do this neat trick where the gauge needles rotate all the way in one direction, and all the way back in a few seconds- upon start-up.
See this vid of the Lexus IS cluster: Watch the speedo and tach needles
YouTube - 2009 Lexus IS-F Gauge Sweep
I want to make my car's gauge needles do the same thing.
I thought i could run a relay that would break the factory circuits to the needle motors upon startup for maybe 3 seconds. And during these 3 seconds, i can maybe use a motor driver to send the right signals to the motors so that the needles swing right and left just like the needles from the cluster in the Lexus IS. Then after the 3 seconds, the relay connects the factory circuit so the cluster performs normally.
My only problem is that i don't know how the gauge cluster motors work. I am assuming they're stepper motors (but i could be totally wrong).
I bought a used cluster from a Lexus Rx330 (which use the same motors as my 2008 Lexus Rx400h cluster) so i can test out the motors before i do it to my actual cluster.
Here is the cluster taken apart. I’m focusing on the speedometer needle motor.
