I've had that happen to on 18f1320 and 16f88 just force erase and she was good as new. The 16f88 has hung more. What's funny is it's only been when I use C18 on the 18f1320 and microC on the 16f88 the configure some how didn't set right. Like it didn't load it all when I programmedHi when i try to program my 18f1320 it does the programming part then says verification failed at address 0x0000. Also all bits are set to 00 when ii read the IC.Is the IC permanently damaged?
It worked nicely.But what i found wierd is that why nothing happened when i tried normal erase before you advised the manual select technique.Did that work? Else you may have MCLR=ON and Internal OSC On, you'll need to connect it to the ICD connector which supports VPP before VDD.
I will be moving to C in a couple of days, thanks for making me vary about the problem.I've had that happen to on 18f1320 and 16f88 just force erase and she was good as new. The 16f88 has hung more. What's funny is it's only been when I use C18 on the 18f1320 and microC on the 16f88 the configure some how didn't set right. Like it didn't load it all when I programmed
