IC Chips
spudgun1992
Hi, im fairly new to electronics so i'm a little confused.
Basically I have a 4069 Microchip as shown below
Now from what I understand, the chip needs to be powered using pin 7 as the negative and 14 as the positive (please correct me if i'm wrong).
Also, the signal which I want to invert using pin 1 is too powerful (12v at 10 amps), or so I believe it is, should I use a resistor to lower the voltage, and if so what should the voltage be for this as well.
Something else that I also don't understand, is why do we need to power the chip, when I'am putting a voltage through pin 1 anyway.
Finally, what do I need to do with the other unused pins, if anything?
Sorry if I sound silly, but after a day of searching around on the internet, I have become a little confused.
Thanks in advance for your help
You need to power the IC with 12V [pin14] and 0V[pin7] if you are applying a 12V input signal on pin#1.
When you say 12V at 10A, what is that,,, a battery or something else.???
Basically, i'm trying to invert the signal from a car's sidelights, hence the 12v signal at 10A. I then want the output signal of this, to power a set of daytime running lights. So when the car's sidelights are on the daytime running lights are off and vice versa.
Hope this helps to explain things a little more clearly?
You're going to need a power stage also to drive the lights. You may be better off using a transistor for an inverter rather than this IC chip. The transistor is more rugged for these automobile applications.
Ok, thanks for your help
Definitely a relay is the simplest way to go, with the coil energised when the sidelights are on, and the running lights supplied via N.C. contacts.
