sahu Member Apr 2, 2011 #1 i have requirer i\p & o\p same pin .i\p as logic high\low & o\p is for relay drive ... it may possible ? Last edited: Apr 2, 2011
Ian Rogers User Extraordinaire Forum Supporter Most Helpful Member Apr 2, 2011 #2 Are you trying to read the state on the relay on the same pin are turning it on? I need a circiut or something. Ian
Mosaic Well-Known Member Apr 2, 2011 #3 And what's to prevent a high input from triggering the relay drive that's on the same circuit?
sahu Member Apr 5, 2011 #4 Mosaic said: And what's to prevent a high input from triggering the relay drive that's on the same circuit? Click to expand... no ....only o\l & short ckt sensing with pic16f676
sahu Member Apr 6, 2011 #6 blueroomelectronics said: Use two pins. Click to expand... in my hardware only 1 pin blank ... pl segues me , help me....
sahu Member Apr 7, 2011 #8 wannaBinventor said: multiplex something else. Click to expand... pl explained it
W wannaBinventor Member Apr 7, 2011 #9 Go ahead and explain what your other input and outputs are like and we will go from there.
sahu Member Apr 14, 2011 #10 wannaBinventor said: Go ahead and explain what your other input and outputs are like and we will go from there. Click to expand... i have 2 pin in 16f676 which are pin no...2 ---RA5/T1CKI/OSC1/CLKIN & pin no...4 ---RA3/MCLR/VPP. i have requirements 2 i\p, & 1 o\p.... (1)_ mains on & (2)_ inverter on and (3)_for relay drive.. pin no...4 is only for i\p .so , how can i use it ?
Mike - K8LH Well-Known Member Apr 14, 2011 #11 sahu, Could you optimize other hardware connected to 16F676? What else are you connecting to it?
sahu Member Apr 16, 2011 #12 Mike said: sahu, Could you optimize other hardware connected to 16F676? What else are you connecting to it? Click to expand... hear hardware connected to 16F676? Attachments SHORT CKT TEST01.zip 21.8 KB · Views: 170
Mike - K8LH Well-Known Member Apr 16, 2011 #13 That schematic would suggest you have more than 1 pin available so what's the problem, again?
