ranatungawk
I need to charge my car battery (12V) from my home when it’s very low. I found this circuit from the internet. Please tell me..
1. is this a good circuit for my requirement ?
2. 1N4007 (1A) diodes are used for rectifying. But I think it need to use 5A rectifiers instead of 1As. If so tell me a what is good for this ?
3. can I use this to charge my car battery when it is in the car, ( with out disconnecting battery wires which are connected with the battery)
about the circuit
This very simple circuit uses a transformer ,two diodes , a capacitor and an ammeter.
To charge a battery just connect the + and - terminals of the circuit to the corresponding terminals of the battery.
When the battery is not charged, the ammeter reading shows 1-3 amps.
When the battery is fully charged the ammeter reads Zero or nearly zero, after which the battery should be removed from the
charger.
The circuit is a full wave rectifier using 2 diodes for rectification. The capacitor is used for smoothing.
I think the circuit works fine without the capacitor since the battery itself acts a BIG capacitor. But when you are using the
circuit to supply 12V (as a battery eliminator) the capacitor needs to be present.
Care should be taken NOT to reverse the + and - terminals while connecting it to the battery.
about the circuit
charger.
